- Joined
- 15 Jan 2025
- Messages
- 187
- Reaction score
- 5
- Country
mystery deepens, i have just drilled holes for my second shelf, about a foot above this one, and i hit masonry on both of them!Do you know what the construction of the wall is?
My guess, and it is just a wild guess, is that it's (from the wall surface inwards) tile, plasterboard, stud frame with void in between, brick/stone.
To clear up the size confusion, the suggestion is that you've drilled the hole too big, because you're using rawlplugs that are too big for the job. So the suggestion is that the hole is therefore improperly sized for the job.
Anyway - that's water under the bridge - more crucially - what do you know about the wall?
My best guess is that there is masonry there all along, but at the first spot i drilled, it was crumbly and damp, this is an occasional problem around here
