Ive got two chimneys as shown below (each with three stacks for ground/first/second floor), in a mid-terraced 1880 house. As Im trying to insulate and improve my house Im part way through planning to put an MVHR in and use the chimney stack (which is out of use) for a fair bit of the pipework.
Is there any reason I cant carefully remove one line of face bricks from the chimney, put in a concrete lintel, and then open up a bigger access to the chimney (probably 4/5 rows of bricks but still surface only, hence not interfereing with the walls between each stack). That will allow me to insulate the chimney void at floor level, and feed an MVHR pipe down to the ground floor. The chimney is between two houses so shouldnt get too damp once insulated, but I can open up the chimney in the rooms more, if it is insulated at roof level.... Once there is access to the chimney stack, I can also feed my MVHR 'external' pipes through the same hole.... (Chimney currently has a basic form of cap on it)
Given the walls between the stack I think I should be ok to remove one row of bricks without any support, before putting the lintel in quickly. Does that seem like a reasonable assumption?
Thanks very much in advance!!
Hence in my mind, would look something like this (with the white being the lintel and the yellow bricks being removed):
