But in the simpler circuit I've just described, flicking the FCU would also isolate those three fan conductors, and leave the pull-switch wiring dead too, when opened. Simpler, cheaper, safer.
As you say, the pull switch serves merely as two single pole switches for the two loads, light & fan. No more isolation that a wall switch does a for light bulb.
Anyone 'unwary' enough to not understand that the supply side of any switch will remain live, even when the switch is off, probably should not be going anywhere near an electrical installafion.
A permanent live for the fan could then have been run more safely/obviously from the input to that simple switch. The fan supply (permanent & switched lives) would have benefited from the FCU's 3A fuse along with the fact this is in turn powered from the light circuit, with 6A MCB back at the fuse box.
No, sorry, this is more complex, more expensive (16A isolator about 3x the cost of a 6A single pole switch); and clearly more dangerous. Remind me what the benefit is?
You can't. Fan & lights both double pole isolated by the FCU with the simpler wiring. I'm sure electricians and DIYer's are well used to working with lights off, by torch light etc.
An electrician has separately told me he thinks the existing wiring circuit is 'wrong' in the sense of safety, and that a warning note should be added to the Fuse Box and/or ceiling switch. I think he's right. I'm not looking for an argument here, perhaps we should just agree to differ now.
It is not done to work on the fan with the light on.
It is done to disconnect the fan from the electrical installation - isolate - should it become faulty and cause an MCB or RCD to disconnect the circuit so that the house lights (and possibly more items) still work until a repair is made.
Add a warning note then.
There are lots of similar situations.
An electrician (albeit retired and another person with similar knowledge) has told you it is not 'wrong'. 2 - 1.
If that is your view, then this whole discussion (about 'clever'/complicated wiring arrangements) becomes totally silly.
If you're happy for the light to be out when working on the fan, you could simply connect the fan to the ceiling rose and then disable (L only) the entire light circuit with its MCB/whatever in your CU - or, if you wanted 'DP isolation', use the Main Switch in the CU.
