I’m replacing the old PIR spotlight with a new one. The new one only has 3 connectors Live / Earth / Neutral but not sure what I’m supposed to do with the LS wire as on the old one? Thanks!
If so do I cut it halfway, and add both ends into a terminal block, along with the LS wire coming out of the cable in the wall?
Grey=-neutral
I was referring to the 3-core & E cable that is still connected to the old light. There are no blues there!It seems not.... Grey is the live, entering the PIR, with a black (SL) going straight from PIR, to the light. Neutral is the pair of blues, one to the PIR, one to the light.
The original (at right) as imprinted on its back box, is saying in order left to right as you are seeing it: Live/Earth/Neutral/Switched Live. The new one (at left) imprinted on terminal block as you see it is Live/Earth/NeutralOh, OK - I'm less certain on what has been used on the original fitting, on the right. I would want to check that out, but the OP never asked about that, and so I assumed he knew what was what in there.
Grey=-neutral
I would put the perm live (brown) in a separate term block. use the switched live (black) as the live feed for the new spot. then you can turn it on and off from the switch and (if the PIR has it) use a pulse over-ride feature.
I’m also not sure what you mean by a pulse over-ride feature, unless that’s a built in feature with the PIR spotlight?
