Shower screen seal
14 Feb 2026
Good Evening All,
I am trying to establish which seal should be used to replace the one that has deteriorated on the shower screen doors shown in the attached images. The seal is between two pieces of metal (metal pole on the right and metal hinge on the left).
I have taken the below pictures and been browsing the interweb to try and find similar shower screens to understand what’s needed but to no avail. I am not sure if there is a grove/chanel on one of the sides (perhaps under the round cap, inside the pole) - is there a way to tell from those photos? I found various seal types (attached) but again unsure if any of these would be any good. Tried AI as well however I get a different answer every time I provide a new piece of information. Time for some real intelligence from experts. Can you please help?
Many thanks in advance and anticipation.
It's usually fitted to the screen on the other side (the wet side) to that shown in your photo and is a 'C' shaped translucent vertical nylon strip that sits between the fixed and moving parts of the screen. I haven't actually seen a seal a seal fitted where you you indicate in your photo.
Looks like a black seal .
