Analogue or digital ?
Thank you yet again @Harry Bloomfield, you have been incredibly helpful and it has been really appreciated.
When you move to fibre, the old copper router, might still have some use to you - an old router can be repurposed as an extension for a wired LAN.
There is a referral to YouFibre here - https://aklam.io/9lBLGzKT
It would get both of us, at least £25 off our bills, if you use it.
Like most ISP's these days, they don't offer or include an email service, but there are plenty of free services available to use, such as Googlemail, and Outlook.
Good helpful post there @Harry Bloomfield. Thank you. I will try and remember it.
Forget one that uses AA cells, get one that has it'sown rechargeable batteries in that get charged from it's stand.
Because you just know, it will have flat batteries the exact time you need to use it in an emergency.
Thank you @mattylad. The 3 handset system that we have at the moment has Duracell re-chargeable batteries in each handset and so long as the handsets are left in their stand they are charged fully. The problem is that the charge doesn't last very long and they are nearly new batteries.
I replace the rechargeable batteries on our Gigaset phones every couple of years. I don’t think being on permanent charge does them any good. Ideally the manufacturers should have made the chargers intelligent.
Thank you @spile. You may have a very good point there. Our existing system has been working vwell for about 6-7 years (I think). Perjaps it is "Planned obsolescence"
Thank you @mattylad . Yes, I will look into that. At least we have got our mobiles in an emergency.
My set of four BT phones, similar to the 4600 model, but even older - I installed around 12 years ago. They were bought as 'refurbed', with a mix of AAA cells in them. Around 4 years down the line, I noticed the talk time reducing, so I bought a full set of replacement AAA NiMh 750mah cells for each. Since when they have all worked absolutely fine.
I think the best advice, is to not go for the highest capacity cell available, because they tend not to be as robust against being on constant charge. One issue I have noted, is that dust and dirt, on the charge contacts, can sometimes prevent the phones going back on charge, when placed back on the stand, after use. Then next time you come to use them, they can turn out to be flat.
Most will have rechargeable batteries in, what I mean is do not get any phones that you have to supply your own with.
I have a set somewhere, not sure why I still keep them - perhaps it's because I'm a hoarder lol.
Thank you for all that @Harry Bloomfield and all to be borne in mind when we decide on our next 'phone system.
Thank you for that @mattylad. I have quite a few items with re-chargeable batteries in, head torches, label printer, oh, and of course do not forget all the Christmas lights that get draped round everywhere !!
PSTN retirement is not the same as full fiber. Landline phones will be moved to "digital" whilst still on copper when the PSTN element is switched off. Broadband can still be delivered via the copper pair, just no dial tone.
Thank you @oceansoul. That was very informative and much appreciated.
Thank you @matlob,. Wow, that was useful ! I've just discovered that full fibre is available to us now !!! But my Internet access is fast enough as it is for what I use it for. Probably because I am so close to the exchange ? I wonder if at some time we will have no option but to go fibre ?
You don't need to go full fibre to have your voice 'line' switched to Digital Voice (Voice over IP).
If you change supplier, or possibly even a new fixed term contract with existing supplier, this can trigger a migration to Digital Voice over VDSL (fibre to the cabinet).
BT are wanting everyone off analogue telephony as soon as possible.
I was moved to BT's 'digital voice' mid last year. No warning, I phoned up to report no phone service only to be told I had been switched over! The new service has been most unreliable, frequently can't dial out, just get error message instead of dial tone, the audio quality is really harsh and shrill too. You have to dial the local area code now too which is ridiculous, as when I forget it plays an automated message telling me to dial the area code. It knows the area code hasn't been dialed, it knows that the line is fixed at my address, there is no reason it can't add the area code automatically!!
