Is this 6mm or 10mm cable?
How far along have you looked? I.e. how many cm away from BASEC have you looked?
It was very normal to have no markings on cables other than makers name
Checking mine with a tape measure I have a Delta Enfield - Basec (late 1990's) 17*8mm and a Doncaster - Basec (pre 1994) 18*9mm, neither have any other markings and both are 10mm²
If yours really is 19*10mm² I think I'd be tending towards 16mm².
A quick google found this reply to a question
Thanks for the contributions and ideas. I might go into my electrical supply shop and ask them to show me both to see if that helps . (y)
You'd be best saying why you need to know the CSA of this cable and are obsessing over the dimensions of the one installed.
Is it the cable to the 'extension DB' in https://www.diynot.com/diy/threads/...hob-from-extension-cu-with-6mm-supply.655113/ perhaps?
it’s live. Not an electrician so don’t want to touch anything.
You will, then, need an electrician to examine the termination(s) of that cable to ensure what the CSA is. Sooner or later. Just going by the dimensions of the sheath is not going to be 100% foolproof.
Albeit many on here will be happy isolating the whole home to open stuff up, take pictures and measurements; then close up and restore power. I've done worse, and once discovered a 1000A TV studio lighting supply was L-N reversed via a 20mm skeleton fuse-holder giving me a shock.
That table appears virtually identical to my one which I put in this forum's wiki, but with someone having re-done the final column (and emboldened it) to include the (so obvious that I hadn't included it :-) ) overall conductor diameter of the three single-core ones (1, 1.5 & 2.5 mm²).
I therefore wonder where you found this slightly modified version of my Table?
If you have a vernier gauge, measure the diameter of one strand, and count the number of stands of copper, in a core. From that, we can let you know the precise size.
Yeah, it's cross sectional area so we will need maths too
It might be better, in the absence of having an accurate measure like a vernier/micrometer to skin it and reshape it so all the cores are in a flat line next to each other (touching) like ooooooooo
then measure the width of all of them together, divide by the number of cores, halve the result, multiply it by itself, multiply it by 3.14, and multiply it by the number of strands again
This will hopefully kill off enough measurement error to give a ballpark
All that said, you've measured 20mm by 10mm roughly roughly, it is unlikely to be 6sqmm CsA
OP - why do you want to know this ?
The cable feeds a separate CU that powers the extension (kitchen and bedroom). I had posted previously about switching from gas to electric ovens as I had assumed it was 6mm.
Then it occurred to me that even 25 years ago they might have used 10mm so took a photo, hence this post.
What size breaker is protecting this cable?
Photo of main CU?
This is the main electric cupboard. The supply in splits: 1. The CU serves the rest of the house. 2. The Mains Switch (bottom left) runs to the smaller CU in the extension. (I’m aware that the cable isn’t RCD protected and should be).
At the other end, the cable has a 100A 30ma RCD at the extension CU. Thanks
So my builder turned the main switch off and disconnected the neutral at the extension consumer unit to have a look..
Here's how 6mm and 10mm lugs match up. The 6mm definitely doesn't fit, even the 10mm one looked tight. Can 6mm be eliminated from the enquiry? Thanks
6mm and 10mm
10mm
