As I see it, there are a few options for you now:
1. You get a competent electrician in, who will use a test meter to look for leakage (e.g. due to dampness) in that circuit, and narrow it down by disconnecting items (e.g. at ceiling roses) one at a time until the problem has been found. (This shouldn't be difficult, but it does take a bit of patience and some experience. A 17-year-old who has mostly been installing wiring in new-builds might not be ideal.)
2. You do the same but without the test meter: this is a much slower process, as you'll need to disconnect parts of the circuit and then wait e.g. a week to see if you get a trip - and live without some of your lights in the meantime.
3. You do the same as the electrician, but using a normal multimeter rather than a fancy insulation resistance meter. This may or may not be able to detect the fault. (The one time I had an RCD trip due to damp in an outside light, I was able to identify it using a multimeter. But that was an instant trip.)
4. You ignore it for the time being. With luck it will slowly get worse. If it eventually gets to the point where it trips immediately or almost immediately, it should be much easier (for you or an electrician) to diagnose.
These all have obvious advantages and disadvantages!
