Well, that's 3 possibilities!
Which just illustrates that no-one can specify a particular hole size. You need to measure the outside diameter of the mixer tap fixing boss and cut the hole to that diameter.
Pick a hole saw that's a few mm larger that the 3/4" BSP tap inlets but obviously smaller then the tap base collars. I'd usually use a 32-35mm cutter, leaves a little wiggle room.
