I have this grey plastic pipe throughout my house in 10mm, 15mm and 22mm sizes. I'm planning to renovate my bathroom, but I can't find any manufacturer markings on the pipe itself. The only markings I see are some part or certification numbers which i cant find any info on but some text is in in polish?
All of the plastic fittings I can see around the house are grey Hep₂O fittings. The house is UK build from early 2000s and from what I've read, the older grey Hep₂O system is compatible with the newer white Hep₂O fittings.
I've never worked with plastic plumbing before, but everything I've read suggests that the pipe, inserts and fittings should all be from the same manufacturer.
Given that all the existing fittings appear to be Hep₂O, can I be reasonably confident that the pipe is Hep₂O as well and safely use the latest Hep₂O inserts and fittings?
Or would it be better to connect to the existing pipe using compression fittings and then run new, identifiable pipe from that point onwards?
I asked at my local plumbers' merchant, but unfortunately the young guy behind the counter did have any ideas.
Thanks for any advice
