Boiler stopped working over the weekend. Green status light rapidly flashing (not locked out)
The first fault listed in the service manual is the pump and the problem appears to be here. On inspection, I noticed a very slight leak under the pump housing where it mates with the boiler. Also water pours out in a non stop if the brass bolt is removed (that's not right is it? ...I expected possibly a drop or two but not continuous leak/flow)
On removing the pump and easing out the impeller, it appears that water has found it's way inside the actual pump ...This definitely can't be right!!
My best guess is that the rubber seals have failed allowing the water inside the pump, after I dried everything out the pump works ok (on the bench) but on refitting and tightening the 4 bolts up , the problem persists and I'm back to square one.
Can anyone confirm my suspiscions ie that water is entering the pump housing due to the rubber not sealing properly? ..or is there another likely explanation.
