Hello..
Firstly I'd like to point out that have no idea what I am doing with regards to this problem, I'm hoping to avoid spending out on something that is relatively simple to fix myself (given that I may as well be a 5 year old when discussing plumbing related things).
I have had a leak from my overflow pipe which I noticed last year but it wasn't very often - this year however it is pouring out virtually all the time and only stops when I turn the hot tap on.
I have read that it could be a ballcock that needs replacing in my water tank in the loft - this is basically Russian to me - also it has been recommended that I turn the water off (haven't a clue how to do that but remember someone telling me the tap was impossible to turn).
If someone could give me some basic (and I mean basic!) tips I'd be grateful - otherwise any idea how much a plumber would charge for this job?
Ali
Moderator's note:
You have multiple threads running. Please just use one of them. I have marked this one " *THIS ONE PLEASE* "
Use the "REPLY" button at the bottom of the page to add more information or requests about your problem
I will lock the others
Ali
Moderator's note:
