Old Chaffoteaux Celtic Plus boiler in house I have moved into. Various problems fixed by BG and boiler working reliably for some time. However have noted CH works fine with all radiators on but if then start turning some off, as soon as only 3 radiators left on, boiler flames go out leaving only the pilot. Pump continues and rads gradually cool. Turning a fourth rad on then causes the boiler to come to life and rads heat up normally. DHW is normal throughout and hot. Rads normally hot or very hot and warm up quickly. Boiler pressure and temperature in normal ranges. BG unable to suggest solution.
Connections to rads are microbore.
Would be grateful for any ideas.
