WHB Connection into a Bath Waste
15 Mar 2007
Lanarkshire
I have relocated the in laws WHB to a gap in the wall between the bath and the SVP. Connected the new 32dia waste into the existing 40dia coming from the bath with a swept tee, the pipe runs from the bath at only a few degrees toward the SVP. Only problem is that when the sink runs away the water bubbles up the bath waste. Is there any easy way around this, non return valve or something. The bath has a flat looking shallow trap.
I can't access the waste pipe to cut a new connection as it runs down inside a brick built box out section.
