hi,
hoping someone can help me with this, had a baxi 105e for about 8 years and in that time the PCB and diaphragm have both failed and been replaced.
now its started with a new problem, when CH or DHW is on it will run for a short while and then the fault light for 'fault on central heating sensor' starts to flash. this happens if youve got water and heating on together or if either one of them is on its own. been doing it for a few days and usually if you leave it for a bit it will start working again and you can get enough water for a shower, but now its finally given up !
does anyone know if it will soley be the central heating temp sensor that will need changing ? or could it be somethign else, also why would the central heating temp sensor affect the hot water ? would this mean that the DHW temperature sensor could be at fault even though its warning light doesnt flash.
cheers for any help and advice
