Thanks for the info. Sorry but as a noobie to this what do you mean with the above?
For the internal corners someone did mention to cut the exact length and place it to the wall. For next section copy the pattern onto the board and cut around this using a coping saw and that should be an exact match. Is this right?
If you simply mitered the internal angles the shrinkage of the wood would create a gap, some people are not bothered by this and cite that filler is their friend.
