is this nomal ?? vokera ?
10 Jun 2008
new boiler fitted ... vokera compact 29 condenser.
occasionally when it fires up theres a loud bang/thud from it , is this the burner igniting the gas in the chamber ? or is it not normal ?
sounds like someone slapping there hand on the casing ,
any help appreciated :?
sounds like explosive ign......
1st thing i would be checkin is that gas pressures are correctly,(not a job for a diyer)
then look at flue to make sure it is installed correctly.....
if it is new - get ur installer back or get vokera out to check it
Case might be loose. Worst cases in the world, if they aren't screwed up properly they rattle big time when the boiler fires.
Four screws underneath the case two at the back and two at the front.
I think we should start a partition for better vokera cases...I hate them!
:lol:
1st time i fitted a compact i took the case off and also took the sur-clip going into the pump housing off aswell !
i had lost the clip down floor boards ! spent ages tryin to find it!
:lol:
Yeah, we could start a petition too :lol:
Don't know how many times I've lost at least one screw trying to fit those cases :x
