water pressure reduced after repair
26 Aug 2008
Glasgow
Hi i turned off water at stop cock to repair leak at d/stairs toilet . When water was turned back on pressure seems to have dropped from cold water taps . The system has a pressure reducing valve fitted above stop cock and is mains fed . System is 2yrs old .
Check the stop cock is fully open and working, or clean the strainer on the pressure reducing valve if there is one
Checked stop cock and cleaned strainer with no improvement . Re generated air gap in mega flow and all is well .
