Only a few years ago a FEL Thermostatic Fire Valve was fitted to protect my oil fired boiler. It was successfully tested OK at each service but has just failed continuously tripped off and cannot be reset. It has to be replaced!
I spoke to Keraflo/FuelStop who took over the FEL product range to try and find out why the valve had failed after such a short time. Their view is that it has failed due to exposure to excessive sunshine in the recent heat wave!! This has resulted in overexpansion of the bellows inside the valve and permanent damage has been caused which is now preventing it being reset. Certainly the valve felt very hot to the touch when I last checked it.
Keraflo advised me to fit a 'sun shade' to protect any replacement product. This all strikes me as ridiculous, and is certainly not mentioned as an issue in any installation or environmental information I have seen. Teddington assure me that their KBB valves do not suffer from this problem so that's what I shall be using as a replacement (albeit with some changes to fittings).
Has anyone else come across this problem with the FEL product? OFTEC were not aware when I contacted them.
