Can anyone help? I stripped the wallpaper of the kitchen wall to find rising damp on the wall about 500mm high from the floor at the door access. We have an extractor in the kitchen so no condensation present.
Looking outside and it looks like the DPC is bridged and this area seems to be wet all the time, see photo of flags abutting the kitchen wall. Even if the weather has been dry for weeks this is still wet. There is a mains water inlet below this area and sewer pipe. I have carried out the Vacuum test using a glass full of water with the tap outlet in the water and turned on, then turning off the main supply in the street and left this for 60 mins with no change to water height.
I have tested the sewer pipe best I can by blocking the output into the sewer and putting a red dye down the toilet, but I could see no sign of any dye. Looking at the photo you can see there is a green line that is wet, is this because it is constantly wet or because it is from the soil pipe.
We are going to part brick the doorway and fit a new window as part of the kitchen refurb and obviously need to resolve this problem first.
Any help will be much appreciated.
