We have a projector that is installed in the assembly hall. A long VGA cable has been run which may be 30 to 40 meters long. At the other end of this cable we connect our laptop. The video quality is fine. When we plug in any speaker to the laptop there is a very strong noise. I have checked there is voltage between VGA shield cable and the power socket ground at the laptop end. It is small voltage. There is resistance between VGA shield and Power ground at the laptop end. We use an isolator between laptop and speaker. It has solved the problem partially. But there is still noise.
Can not figure out how I can solve this problem. Any suggestion will be highly appreciated.
