Right, I took delivery of my suite today. I had previously emailed the manufacturer and asked if there was enough room behind pan to wall to get a 90 deg pan connector out and to one side (horizontally), they said yes.
After measuring I think not, sorry about the yellowness, it's my cameras indoor settings!!:
http://img260.imageshack.us/img260/3739/wc001uy1.jpg
As you can see there is 70mm from edge of pan to wall, level with waste connection, whereas a 90 deg pan connector is 100mm diameter before entering the 5" (?) soil connector.
Looks to me like the pan was designed for connector to go under floor:
http://img104.imageshack.us/img104/8480/wc002ts2.jpg
Can anyone advise on what to do here? It will be installed about 1-2ft away from soilpipe and wanted to connect horizontally, then box pipes in afterwards.
To me I can either:
a) chase into wall to allow pipe diameter
b) set pan away from wall slightly to allow connector
c) use a special connector for this purpose!!!!???
d) go under the floor?
My joists run at 90 degrees to the direction the waste pipe would need to go to meet soil.
What would a pro plumber do?
To me I can either:
