- Joined
- 28 Feb 2024
- Messages
- 4
- Reaction score
- 1
- Country
Hi, I have a Chafoteaux Maury Britony combi se 80 ... Yes I know
... it came free of charge with the slightly delapidated flat I recently bought and worked fine for the first 3 months.
The heating is working fine but the hot water is now luke warm at best and only fires up the boiler when the taps are fully open. The luke warm water is constant and not fluctuating.
At this point I did the right thing and called in a boiler engineer from a mid sized local company.
He replaced the three way valve, motor and divertor valve cartidge, gave me a thumbs up on the way out the door and a bill for the work. I've paid the bill but it's not solved the problem.
The hot water is now slightly warmer but still only works when taps are fully open.
So I got my tools out.
I did some home work and I've now replaced the plate heat exchanger. tested and for luck changed the thermistors, swopped out the pcb and flushed the central heating system. Still no joy.
I can't afford to have the boiler replaced at the moment, so if anyone can help, it would be very much appreciated.
