- Joined
- 15 Jan 2025
- Messages
- 145
- Reaction score
- 4
- Country
Hi all, i'm drilling holes for shelves today in my bathroom, i'm using 8x65mm plugs, so i drilled a hole that deep, and actually a bit deeper. 830mm is the depth of this hole, i know because that's the entire length of the 8mm wide drill bit i used, i kept going hoping to hit some brickwork and never did
The drill went in all the way with no resistance, wasnt even on hammer mode, i hit nothing solid. Which seems impossible, gotta be some masonry in there somewhere
I put the plug in, i'm trying to turn the screw, and the plug is just spinning, deep in its hole. it isnt providing enough resistance. If i turn the screw, it turns, but nothing happens, no resistance, just spin
The screw can be wiggled around in there easily, its like the plug has burrowed a little cave in the plaster. Video: https://drive.google.com/file/d/1om6BmajFfWq_lpsGjNnOS8xwEGo3bXGj/view?usp=sharing (you may have to download unless you're viewing this several hours after i posted it
This is a problem
I need to install at this exact spot, i really don't wanna do it elsewhere
this shelf won't need to bear a lot of load honestly, its just gonna hold razors and shampoo bottles, but i've gotta get it screwed in
The other screw is perfectly fine, there's a solid wall there and no issues
This is a problem
