I am taking my bathroom wall back to brick in order to fit cement boards before tiling.
After removing a section of plaster to expose a couple of bricks, I found the brick pointing to be crumbling and pulling away with just my fingers.
- Is this lime mortar pointing? I put a piece in white vinegar, and it actively fizzed, so it probably is?
- Do I need to repoint the walls before fixing the cement boards? Or can I get away with leaving it as is?
- If I do need to repoint, how do I go about it? Rake out a few cms with an angle grinder, then repoint with lime mortar? What type of lime mortar should I use? Any particular brands?
