Bathroom LED mirror wiring
8 May 2012
Durham
Hi all
I’m currently doing my bathroom and I want to fit an LED mirror (with de mister??) to the wall opposite the bath. There was a shaver socket on that wall wired directly into the bathroom lights (1.5 T&E) Can I just reuse that wiring as im getting conflicting info or do I need to run a fuse spur from the socket ring to it?
My lights are not on an RCD protected circuit…. when the house was wired 15 years ago, it wasn't a necessity (something about bulbs popping and tripping everything).
I can take a spur ir even add to the ring, from the socket on the landing and add a fused switch above the door with the extractor isolator, it’s just a bit more work.
Any advice would be great.
Cheers
Yes, except:
Well no, in that case. You should fix that. No reason for non-RCD circuits in 2025.
Can you run a led mirror and demister from a lighting circuit without any issues or should they be on a fuse (best practice?. It may be easier just running from a spur
Cheers for that. It may just be easier to run a FS to the blanking plate above the door then a cable to behind the door
Yes fuse spur.
The lighting (and fan) isnt on the rcd though, but the sockets are.
Firstly, I think you should really consider having RCD protection on your lighting circuit.
If you do that, then you can connect to the lighting circuit at the box above the door next to the fan isolator.
Otherwise, a fused connection to the RCD-protected socket circuit is an option, if you can find a sensible route for the cables.
