- Joined
- 18 Apr 2022
- Messages
- 5,847
- Reaction score
- 803
- Country
Not so; I think you may be confusing Pozi and Phillips. Phillips are designed to cam out because they have angled sides and are found in industrial application where a machine is driving the screw, so pressure and angle are consistent and the robot needs the screw to separate easily from the bit when it's done driving
Ah - OK - thanks.
Keep a stock of PZ2 bits and swap em out if they've bounced around inside too many screws or look visibly propellered
I do know I'd much rather have soft bits which get bollixed when they slip, and can easily be tossed, than hard bits which bollix the screwhead.
