Serious Mold Issue in Master Bedroom
All together prevented by adequate ventilation being given, not drying clothes on the radiator and having an extractor or opening a window in the bathroom.
We are well sealed up, never open windows in winter, yet we have no mould anywhere. How do you account for that? All we do, is ensure no excess moisture is generated in the home, and what there is - ensure it is extracted it at source.
If it was any good everyone would use it instead of 100mm+ kingspan. 3mm of polystyrene wallpaper doesn't defeat the laws of physics that thicker proper insulation has to adhere to
That's a little harsh - Every little helps, even a little is better than none at all.
I think you have to do more than just wipe away the existing mould, it has to be de-contaminated, the minute spores can lay dormant for years and come back again.
In our house, cavity wall, we rarely have any windows open in winter, no extract fan at all in bathroom !! ( never got round to putting one in ) and there's sometimes condensation on windows, but there's never been any mould at all.
If I was you, I'd look into properly cleaning/killing-off the existing mould, fit an adjustable air vent and make sure there's no damaged guttering or brickwork around the windows. See how it goes.
Not much, should do. Will start opening them on a morning for a bit.
Open everything every few days before you put the heating on. Every few days I have every door and window open for about 5 mins swap and clean and clear the air. Even when it's wet outside the air is still dryer than it is inside with everything tightly shut up
I cannot believe that to be correct, here is my log, for the past couple of days.... We never open windows in winter.
The green line is the indoor humidity, the brief rises, are the result of taking baths, the sensor is across the landing, from the bathroom (ignore the spike, near the middle, it just a data glitch). The humidity rises quite rapidly, as a hot bath is drawn, but that humidity, gradually reduces over the next 30 minutes, as the moisture is drawn out by the bathroom extract fan. The result - no mould at all. The decline in the blue line, on the right, is the result of the sunshine, this morning.
If you cannot see how you are different Harry then I do hope that you have a jolly new year celebration..
Maybe the dip after the bath rise is the humidity spreading throughout the house as it wafts past the sensor opposite the bath room
It quickly returns, to pre-bath level - if it simply dissipated throughout, then it would last longer/remain higher. It normally shows a similar peak, when we cook at home.
To the OP. Have you checked that the ceiling isn't getting damp from water ingress? e.g. your roof is leaking.
Humidity is relative. You take say 1000 litres of air from outside at 10 degrees C, and if it had 9.4 grams of water evaporated in it, it would be at 100% humidity (saturated, can't hold any more)
Warm that up to 20 degrees C and its humidity would be about 55%
Same volume of air, same volume of water evaporated in it, different temperature, rH drops
It's why condensation even forms; your house air at 20 can hold X ml of moisture per unit volume, but put the air next to a cold window, cool it to 10 degrees, the air can't hold the moisture any more so it condenses on the window
I think what aveatry was getting at when they said "outside air is drier" was "outside air, when brought in and warmed up, can hold more moisture than it did when it was outside", and also "potentially more than the air in the house"
I say potentially because you have to work the numbers
Air at 10 degrees is 100% (saturated) when it has 9.4g of water in it. At 20 degrees it's saturated at 17.2g
If you were to bring a cube of 100% air in, at 10 degrees, with its 9.4g of water (it's just about to get misty, the world air is saturated) and warm it to 20 it would end up with 9.4/17.2 = about 55%
If your house air was only 50% rH you would be bringing more moisture in if you opened those windows, than your house air already had
If your graphing software is tracking outside and inside air, it might also be useful to add a shadowing line of "what would the world air's rH be if brought in and warmed up to the temperature of the house"; if the shadow line is above the house line then there isn't any point opening the windows to reduce the house humidity (but it might have other benefits such as reducing CO2)
There's a consequential element, that the fan is drawing world air in through gaps and cracks, and that air is then heated and is likely to be drier than the house air - it's not necessarily that all the moisture is drawn out by the fan, but also that the fan helps draw in drier air into which the molecules can evaporate and not have a condensing effect elsewhere.
All in you're clearly doing a good job of arranging a stable indoor climate that can buffer and deal with humidity spikes caused by human activity; your uncontrolled background ventilation through gaps and cracks, supplemented by negative pressure systems when spiking occurs, well tolerates your personal activities
Every few days
It's quite likely for a typical UK house, leaky/draughty as they are, that the air will have changed several times per day anyway; your irregular purge may not be doing as much as you think
Note that it may amount to needing more than that, and you should really be putting some science behind it, with a few hygrometers around the home or even better, ones that track/graph
Having the windows (or their trickle vents) open slightly on opposite sides of the house, so there is a trickle of air through, having the heating on so the room temp doesn't dip too much (stay above 14)
Not closing curtains and ensuring there hence isn't a compartment of air in the room that is cooling massively, but can then sink and draw warm moist air in at the top of the curtain, cooling it and condensing its moisture like some kind of passive dehumidifier
Changing the heating (and potentially insulation) strategy of the house (do you heat for the morning, have showers, cook, set washing out etc in your nice warm house, then exit, heating off, house cools over the course of the day, the air in it can no longer cope with the amount of moisture laden in it as it cools..) so it remains above condensation territory in internal surfaces
There are a lot of things to consider about how you use your house; ultimately to keep mould at bay you need to understand how you load your house up with moisture, and how you deal with that moisture. Empty, ventilated, unheated houses typically don't go mouldy so you contrast your behaviours with that reference base line and have to keep a balance; if you add moisture, add heat, ventilate it away, balance the heat and the ventilation because essentially you have to throw away paid for heat (unless you mitigate that with technology like an MVHR) - most people are reluctant to do this, so they seal themselves in a box, warm and moisturise it then raise complaint when the inside of the box goes mouldy.
They probably wouldn't raise the same complaint about the kids' school lunch box, left in a warm bag in the lost property of the school for 3 weeks, biohazard as it would become .. but it's the same process..
I do, of course, understand all of that - I was referring to Aveatry's need to fling open windows, in mid-winter. Given proper ventilation and extraction at source, and sensible rules in the property, there should be no need to fling open windows, and suspect even doing so, wouldn't help much.
Most older homes, are naturally leaky, but mine was built with 4x double brick, permanent, through the wall vents. I've since sealed those up completely, on both the inner, and outer leaf, plus improving windows, and doors - yet there are still plenty of holes in the fabric, for outdoor air to be drawn in by fans.
All preventing mould needs, is some common sense measures in place, and care for the building.
I do, of course, understand all of that - I was referring to Aveatry's need to fling open windows, building.
For the record I do not have any mold issues, I dont need to fling open the doors and windows but its something I do, feels good to have a change of air and I was offering it as a part solution to the OP.
Hello, we live in a 1970's Semi Detached Property and have a serious mold issue that has be on-going for many years now. There is no mold anywhere else in the house except for the master bedroom where alot of mold has formed on the windows and ceiling, damp has also caused the wall paper to peel around the windows. The heating is always on the in the winter months and this room is always kept a suitable tempreture. The room used to have an air vent leading to the outside but was removed a long time ago. All of our neighbours dont have any mold or damp in their bedrooms as we live on a housing estate where all properties are the same. The master bedroom is also located next to the bedroom and is at the rear of the property, thank you. I have also attached some pictures down below. View attachment 403267View attachment 403268View attachment 403269View attachment 403270
Probably due to the lack of ventilation, after the vent was sealed. Do your neighbours still have the vents?
Crack the windows in the morning, open them fully for an hour daily weather permitting. Invest in a dehumidifier powerful enough for the whole house, not the just a room.
Make sure the bathroom and kitchen is vented during use.
Check the temp of the surfaces where the mould is growing. A room may be heated, but an external wall may still be cold in winter, and its the warm air meeting the cold surface which causes the condensation leading to mould.
So vent, heat and use a dehumidifier. Worth trying anti mould or anti condensation paint.
