Honeywell T3R expertise please
17 Apr 2007
My T3R wireless thermostat, when set to Auto, has P1, P2, P3 and P4 for time/temp settings.
Can this be changed through the settings to add P5 and P6 which I've seen in some YT videos?
I've searched online for such a menu setting but no joy.
Hi, not something I’m aware of, fitted loads of these, but rarely venture into the programming side as vast majority of our customers want manual on/off.
Thank you, reading the instructions has helped with another consideration, but 1772138023644.pnglooking at the picture I can't see how you could get more than P4 to show on the display, so even in installer menu can't see it being available, but one would need the thermostat to test it. It does show
in the instructions, so worth a try.
As an update, from my own research, the code I want is NP (number of periods) in the advanced menu. NP is set for 4 or 6.
NP is not actually listed in the advanced menu and neither is 1LA which sets the language.
I used code FS to do a factory reset but that did not loose the binding with the base unit which is meant to happen. I did however have to do the date and time.
I need to discover why the codes are missing.
Maybe this will give you a definitive answer
Having contacted Resideo and provided the part no for my T3R thermostat, they've told me that its not a retail product so only has four time/temp periods. Only the retail type have the six.
I'm curious if mine is not a retail product even though it was supplied in a printed box c/w instruction leaflet, what type of Honeywell product is it?
