Threshold strip for wooden door
13 Jun 2015
Antrim
Hi folks,
I'd like to replace the current strip for a wood front door. It has a seal of sorts, but is currently cut into the laminate flooring. Since I'm planning to replace the laminate as well, it would be good to replace with something that is also a transition instead of cut in like this.
Seem to be a lot of different types of these, but I can't find anything similar that also sits on/transitions from a laminate floor. Any ideas?
Many thanks,
Baps.
Is that two different strips?
When I zoom in it looks like a normal carpet door strip with one edge cut off then another brass strip stuck down with rubber draft excluder
Hi Wayners. As far as I can tell it is a single strip with like a cavity in the middle to press a seal into. I could probably replace the seal, but really the finish with the floor is a bit crap.
It's called exterior step nosing trim.
I think that's a tile or laminate bar but nothing I can see online like it
Thanks Wayners. Don't specifically want the same product to replace it, just not really sure what to replace it with that will give a better finish. I see those nosing trim strips, do they install on top of the laminate?
