Adding 8XP wired to a Texecom Premier Elite 48-W
23 Apr 2026
France
Hi all,
After installing the module, I don't see any N1 zone in the zone setup.
Confirm devices display :
Net RKP > 12..
1 EXP > 1...
View Exp. Stus display :
N1,E1 12345678
Zones HAHHHHHH
8XP connected from Network Terminal IN to PCB Layout
How do I activate the 8XP Expander Zones ?
Problem is fixed.
It was the T wire on IN terminal that was disconnected.
Glad you found your issue and ressolved it
Only ways a keypad or expander doesn’t register
Wiring (wrong)
Power (usually not enough, long cable run)
Conflict of addresses (same address on 2 keypads or two expanders)
Interference on data lines
