Stock market dealing
I just edumificated my home help a bit. She's making money!
You need 3 main things
1) A "Catalyst" like a trump tweet,, something in the financial press, maybe just a swing in sentiment
___1a) you need to know a few relevant names, like Korea for overnight plays, active banks, which names are associated with AI build-out, like GEV, CAT, AMAT, ALAB, Dell, HP, SMC, many others. Hot names of the moment, are like memory makers Micron, Sandisk, Samsung, SK Hynix
2) Find a setup Something like a pullback on a rise, or a break above a previous Level. Some learning needed here.
Learn about the Indicator "VWAP", because everyone uses it - it's a self fulfilling thing. (Volume Weighted Average Price). And Volume, which a decent platform should give you.
3) Execution. Know how your platform works, so you can use preset orders, limit orders, stop losses. You ALWAYS PLAN - need to know where to get out if your plan doesn't work, and where to set a "Take profit" if it does. You need a 2:1 or more, ideally 3:1 or 4:1 potential gain. (profit:loss) Then you can afford some fails. Your Take profit" may depend on something else, like the oil or bitcoin price.
Then it's easy. Always go WITH the trend, and never enter unless you have several of the ducks in a row.
Never enter "because it looks like it's doing well". It will instantly turn on you. Sod, is alive and well. If you must enter, use 50p.
Plenty more of course, but that will keep you solvent, if you only use a small amount of your "pot" on a play.
2% they say. Open to interpretation.
Always look back and see why you lost, if you did. It's probably, mostly, your fault.
"Practice in a Simulator", stops you losing any money at all.....
I've just seen a " lesson" which deals with where many people go wrong. NB "coming in" means falling:
It starts at about 3 minutes in, with the dark guy Neal doing a pre-explanation. These guys are both highly successful professional traders
(ask if translations are necessary - platforms differ).
Worth listening to the guest at time 03:02 ET who speaks of $LPTH. Shows the sort of thing to watch out for.
S&P 500 isn't buying any spacex for a set period after launch. It will be 0.01% when they do or if they do so I'm not bothered...
All seems madness to me. I can't see it ending well
Pip pip!
"George Steer and Peter Wells in New York
Published YESTERDAY
Updated 06:59
Elon Musk’s SpaceX shed $400bn in market value on Monday in a fresh bout of volatility for the rockets and AI company following its record-breaking Wall Street debut.
SpaceX shares ended Monday down 16.4 per cent at $154.60, leaving them 31.5 per cent below the high struck after the group’s $86bn initial public offering on June 11. The shares were listed at $135"
FT.com
I never bought any spacex although if you hold for years it could be ok..
Maybe.
I'll watch with interest.
I recently bought £200 in Rathbones..
Continental is also doing ok for me so I'll hold.
SpaceX could indeed be the big company which owns everything and everybody, in years to come.
Elon has the best "AI Stack", which means capacity, basically. He's building the world's largest Data Centre, in Texas. He's out in front in several areas.
It could be a real monopoly. If he can buy the competition, use space (if it helps, which I'm not sure about but he IS clever), he'll be unassailable.
Google and Anthropic appear to be the competition. He could buy the latter, eventually.
His Grok isn't bad, but at the moment Claude is ahead. It's remarkable, but it does get a lot wrong.
Claude is pretty good with stock market trading already. There isn't an active Agent just yet, but the first to get one going will have a money factory.
Elon's weapon may become financial. If he has enough money, he could take all the available cash which something like Anthropic would want to get its hands on. "Don't invest in Anthropic, invest in Musk and get a better return".?
People on South Korea are keen to borrow money to buy the stocks (AI chips, loosely) made there. The market there dropped 10% a couple of days ago. That's huge. It went partly back yesterday, and today Micron (memory chips) in the USA returned excellent results and their shares ballooned.
SO now Hong Kong and south Korea will probably follow
It's 1:20 . in an hour, Hong Kong will open and Hua Hong Grace Semiconductor will go nuts like it did yesterday.
What one does is place a pending order at price which will be hit when it rises. Yesterday it was at the yellow dashed line.
168 --> 192 is a pretty decent rise, at 5x.
I'm off to bed , and I'll see what happens when the price hits the dashed red line. Maybe 209 this time?
Did it work? Yes but.
I put the trigger too high, so some of the gain happened before the trade started.
Blue would have been better than Green
Still, it stopped at 197.4, out on the trailing stop, by the grey.
Therefore about 197.4/194 = 1.7 % instead of 197.4/192.5 = 2.5%
It's leveraged, so 1.7x 5 = 8.5% up, on 10k, which is ok for snoring.
There's a strange "rotation" going on. The big chip mfrs like NVIDIA and AMD are out of favour, as are the AI owners.
The thought appears to be that they're circulating money rather than really making it.
Meanwhile the so called "picks and shovels" cos, who make the stuff that goes into the chips and data centres, are doing well.
Micron's results certainly buoyed the market, which means it's fragile, something small and bad could fracture it all. My plan is to wait until mu holdings are rosy , and get out, but I've said that before.
Bought some GNK, a shipper, at the red line.
I wouldn't let it drop much, Take Profit about 24.8
If it moves 5%, that's fine in a few days. (not leveraged).
Kraft Heinz showed up as a "swing"" stock in the Finviz Up-Channel screener, post 1267.
It worked, for 5 - 6% in a couple of days.
More reliable than trying to guess what the gulf-influenced Tech stocks are doing.
It might go higher, but the "highs" are coming down so I took it out early,
Leverage of 5x is possible with these. It only costs a tiny% to do that, and gives 5x the gain - wish I had.
Overnight trading often works for extended periods:
When the chips do well in the USA during the day, the Hong Kong market, which opens at 02:30 and closes at 07:00, follows, most of the time.
Note the percentage scale. If you use Spread betting or CFD (platform types) you get 5x the move,
Set a "stop" (which really means GO!) to open a trade only IF the price goes UP.
Use a trailing stop, or a fixed one, to take a profit.
Those rises add up to say 20%. Leveraged , that's 100%.
So you double your money in a week, while you're asleep.
We're in an UPTREND, so if you cock it up you can probably just hold on a day or two, because it's going in your direction - it just means you can't play with the money when the western markets are open... Place a stop while the market's closed (ie daylight here) in case it falls.
I wouldn't put all my wordly wealth on it,, but if my normal "unit" is 100, I have no worries using 30. I get it back by morning.
@motorbiking and anyone else using Interactive Investor
What a dog when it comes to tax! No help whatsoever . The trading history downloads don't even give the fund name.
For Excess income on non-reporting funds, they give you completely nothing. It's hours of work looking up individual fund dates for when it's arisen - ugh. CGTCalculator.com helps a lot but only so far.
They refer in the verbage to a CTC report for interest earned, but I can't even find that.
AJBell just split it all out, on a form approved for submission to HMRC.
So far I've got away with overestimating payments.
Finally found a very meagre document at ii.co/uk/secure/document-history . I cant access it from the tabs...
I've been battling with Interactive Investor long enough. They are positively obstructive.
I thought I'd ask Copilot - it has been useful looking things up.
Specifically , ii don't give you data you can use to check reporting status, or those dates for the paid back in dividends, etc.
This is what Copilot says:
With AJBell, it's one click and it's there to copy/paste.
So I have to look up for each fund, the Sedol to find the ISIN, then whether it's Reporting or not, then go to the fund date to look up the dates.
Incompetent. I daresay there IS software to do that for you, for a fee.
Interactive Investor let you put stop and limit orders in a few places that AJB don't, and you can hold USD in an account saving exchange fees.
They are cheaper once you have over about £130k altogether.
Time to look at Interactive Brokers. They charge for most things but at very low rates, as far as I can see so far - they're complicated.
IG screw you on exchange rates. 1.4% round trip on everything. I'll keep an account there with a few quid in just for the info they give.
eToro is a very amateur-aimed, horrible deceitful platform. They charge like rhino for almost everything despite claiming to be free. But when my wife died (October), I wanted a diversion so I stuck a grand in to waste.. Every now and again I go heavy (relative to what's in there) at 5x, on the phone app, when something's hot. I noticed the other day it's at £7k now.
I'm largely in cash right now. There's some solidity in the healthcare sector, eg Pictet Biotech fund, but that may not last. There are a lot of extreme valuations out there. We could easily be on the verge of another 15% dip I think. As before, triggered by Trump.
Regarding Excess Foreign Interest, a real pain for rigorous CGT calculating, there's a big Excel file at Hargreaves Landsdown where you can look up the offending (non reporting) instruments and their paying dates. You need an account to dig in to find it. I can post it somewhere for anyone who wants it. It's on the Statements & tax documents page.(@motorbiking )
Depending on bands and levels, if you don't declare it you may pay CGT instead of Dividend tax, so you'd pay a bit more. At higher invested amounts the reverse would happen. I CBA to work out the threshold! I doubt the HMRC would push, but if they have a wunnerful calculator then it might be simple for them.
