Triton T80Z Fast Fit Solenoid Valve
15 May 2022
Cork
Ireland
Daughter's (Feb 2023) 9.0kW Shower takes ~ 15 to 25 secs to reach its normal flowrate after pressing the start/stop button, it looks like the solenoid valve plunger is sticking while opening but not while closing as it shuts the water off instantly on pressing the button. The coil checks out fine, a resistance of 3.66k ohms, 236V at the coil terminals when energized and ~ 233V after the microswitches close. The water is perfectly clean with no limescale.
O rings are not supplied with the replacement, wonder has anyone had any problems with reusing the old ones?.
For interest, below shows a typical diaphragm type solenoid valve like the Triton uses.
Can ya not buy new o rings?
I didn't see them on the Triton or other websites, obviously you can get (a box) of them after you remove the solenoid valve but this isn't very convenient if you are 50 miles or so from the "shops".
Yeah.
It's not Ideal.
Triton do a fixed price repair or plumbers will carry mixed packs of o rings.
Problem is o rings come in very specific sizes so you need to be sure they are the right ones.
Up to you if you want to try the old ones if they look ok. Probably be ok as I've done similar in the past.
Depends if you can wait for new ones or not.
