The mole!
27 Jan 2008
Llanfair Caereinion, Nr Welshpool
With the help of our cat, it came into the house through the cat flap. We could hear something around the fridge did not know what at the time, so put down humane mousetrap. Mole it seems strong enough to lift the lid and get out again.
However, cornered by the cat, so grabbed it, lovely little fellow, so took it outside and released it.
Then signs on how it was digging under the front door step, where we had not continued the brick sets right to the house, so out with the angle grinder and cut a brick in half length-wise, to fill the gap. 1787150331328.png But it has not stopped him 1787150397947.png he has found another way under the door step. 1787150447147.png He has just moved, suppose it does not stop us using the step, so moved the sand, and suppose we will need to live with him.
I am sure the cats will catch him again. Problem is they are show-offs. And will bring him in again to show how good they are, but if I get him again he will need flying lessons as I will throw him away from the house as far as I can.
Why can't he just dig the garden for me?
Have you got no hardcore etc under the pavers? Are they laid on just soft sand/earth?
That's the point, they are laid on the old concrete slab, there was some concrete stuck to the bottom of the slabs, so to stop them wobbling I put a small amount of sand between the slabs and the brick sets, the brick sets did not quite touch the house, so cut one in half long wise, to fill that gap, but it still managed to get under the slabs.
It took ages to cut that brick in half too.
