Hi there,
I have one radiator in the house which is always cold, all the others work fine. The baffling part is the pipe leading up to the radiator is hot, and it's even as hot as far as the manual valve, however beyond that the radiator won't heat up. At first glance it might appear the valve is the problem (I'm not the most knowledgable on plumbing), if that is the case how would I go about remedying it? If not, any suggestions would be greatly appreciated. Before I forget, I did try bleeding said radiator but clear water came out immediately.
Thanks,
Jon
Thanks,
Jon
