10500 / 240 = 43.75A, You need a 45A MCB, and the RCD lacks adequate switching capacity, is this a split board? I would advise a B45 30ma RCBO on the non RCD side of the board. (if such an item is available for your board)
It is also worth noting that this work is notifiable to local building control
