10ma RCD, Protek (not Proteus) ok, or worth spending more
28 May 2008
Anyone know if Protek 10ma 25A DP RCDs are ok?
Only ever used MEM MG MK RCDs, never Protek.
I assume they must be re BSEN compliant, although lifespan might be an issue. Price is as much volume related on RCD/RCBOs.
It's for a relative in a Clipsal RCD-Skt box glanded to plug, simply because the dumb *** keeps cutting a hedge trimmer cable. Yes I know 30ma is sufficient, but it is close to ventricular fib on the charts. Ground is always pretty wet since it is near a brook on higher ground.
I installed a protec splitload cu on Saturday for a customer.
No problems with the rcd under testing x1 = 18mS & x5=12mS
Sounds good, ok, Protek it is, will test with RCDT320 anyway - just in case it turns out to be a switch :wink:
Thanks.
