When I had a new kitchen installed, I changed all the plastic MK sockets/switches to MK metal ones.
Apart from the fact, that they were slightly larger, and as the walls are already tiled, it's a pain trying to get them to fit together properly.
In one section, I've a fused spur, Double 13a Socket, and single light switch side by side. I was removing the light switch to make the connections, and noticed that when the face plate of the switch and socket touched, it caused a small spark. I put my basic steinel volt meter across face to face, and it registers 110v. After I took the faceplate off, I measured between earth cable, and socket faceplate, getting the same reading.
My fuse panel is a 2 section type 'Crabtree Starbreaker', with lights and cooker in one section, and the sockets covered by a seperate RCCB.
Any ideas?
Any ideas?
