2 cold rads, others hot, low boiler pressure
25 Oct 2010
Bristol
I have a 3 year old flat, obviously not had the central heating on a great deal over summer. I turned it on for the first time the other day. there were 2 radiators that were cold all the others were boiling. as you should do i bled them till water come out. now all the radiators are not working properly, the two which were cold are still ice cold and i have to keep bleeding them all.
Being a man i did fiddle at the boiler and twised something that emptied water out also the bar pressure is under 1 if this helps anyone
Just spotted that! :shock: Not really a good idea to mess with buttons on boilers and you may find it will leak continually.
What boiler do you have?
i have bled all radiators the 2 which wre not working didnt have any air in, once i bled them i turned heating on and sounds like there is water dripping wuit loud into the radiators.
boiler make sentinel x100
Via the filling loops, top it to 1.5bar
images
Sentinel x100 is the inhibitor put into your system, I'm guessing it's on a sticker on your boiler?
There should be another name on the front of the boiler, maybe somewere around the pressure gauge?
thanks all for pointing in the directions needed all usefull coments apart from the last one, all sorted now thanks very much saved me just calling someone out
