hi all,
mother in law calls to say she has no hot water.eventually find junction box for valves in garage loft.when controller calls for hot water, voltage on cable to valve motor(brown) and nothing happens so i'm assuming motor is not driving the valve and making the contact at micro switch to start boiler and pump.I note from various electrical drawings online that it shows the tank stat in series giving the signal for demand to the valve.on hers its open and i can only assume it operates at temperature and signals a relay to cut connection to pump and boiler when temperature is attained.i operated the tank stat manually and voltage passes no problem.my question is that i assume that because the stat operates a different relay it will have no effect on the controller asking the valve to operate because its open and where is this relay likely to be???.
thanks for your help in advance.
