I am trying to put a dimmer switch on what I thought was an existing one way switch at the top of my stairs. I have got two cables into the old switch box. One is two core and earth with the red cable going into the old bottom 1 way terminal and the black cable going into the other bottom terminal. The second cable has only one red cable and that is connected to the top Common terminal.
Whilst trying to connect, having switched off the power to the upstair lighting circuit, I find the red cable that was fitted in the 1 way terminal is still live. Might I have two way lighting to the downstairs hall light despite it being fitted with a one way switch?
Also, any help on how to wire up to a new dimmer switched marked ~/, L1 and L2. Thanks
