12 Aug 2022
Hi I’m in need of some advice..
I have a fault with the indicators on my 2011 Vauxhall Vivaro
The passenger rear side indicator doesn’t flash. the front & side indicator flashes and ticks extremely fast but the drivers side works fine front and back and ticks at its normal rate. I’ve checked the bulbs and non had blown but I replaced the indicators bulbs anyway and still didn’t work.
There is a lot of aftermarket equipment taped into the wiring loom witch is a complete mess from previous owners so working on it isn’t easy. Can you advise what I should do
Check the feed to the bulb holder. If that’s okay, you have a bad earth on the affected lamp.
