Howdy Folks...
Slightly oddball fault. I've had a 3 phase inverter for some time but never got round to fitting it, lent it to a friend as his went wrong, he used it & all was fine. He gave it back to me the other week & I decided to fitted it this week to my garage.
I have wired it in to its own MCB in the consumer unit in my garage. I have fitted a double pole switch in line with it (to aid isolation). The inverter switches on fine & runs OK, however if I switch off the inverter by the double pole switch it trips the RCD in the consumer unit. I can reset the RCD & all is fine. If I switch it off via the MCB it doesn't trip the RCD. The inverter runs on for a while with no load when the power is isolated.
I don't get how double pole isolation causes the RCD to trip but single pole isolation doesn't.
Thoughts please!
Thoughts please!
