- Joined
- 16 Mar 2005
- Messages
- 51
- Reaction score
- 2
- Country
I have a vented fully pumped system, using a 3 port divertor valve, there seems to be plenty of heat in the pipe going to the hot water tank (120L tank) and the radiators are very hot to touch. However the hot water takes 2 hours or more to heat from cold, I don't think that this is how it should be.
I am wondering if there is something wrong with the set-up, it is 22mm to the divertor and going to the radiators, but the hot water tank feed and return are 15mm. Is this correct and does this provide enough flow? What else could cause the tank to take so long to heat up.
Andrew
Andrew
