3 switches
31 Jan 2005
I have 2 lights to connect to 3 swicthes, each of the 3 switches is suppose to operate the 2 lights from different angles, how do I go about it?
Do you mean from 3 different places, or do you just have very wonky walls?
Try the For Reference topic - 3-way switching...
I have to connect 3 switches to 2
lights with 1 switch downstairs and the other 2 wsitches upstairs and each of the switches have to control both lights
thank you very much for your response. I have got a solution to this problem any way. But I will still stick to your advice cos I may get more hints from there.
My regards to every body.
yea, it's exactly the same. It's actually explaining the diagram I have now.
Thanks a lot
OK - my apologies - the only reason I asked was because I read
"thank you very much for your response. I have got a solution to this problem any way. But I will still stick to your advice cos I may get more hints from there"
as being a bit sarcastic, when I'd pointed you at the For Reference topic as that's where your answer was....
