3 way diverter geometry.
15 Apr 2008
Derbyshire
I am trying to find a three way diverter which doesn't follow the normal T geometry, ie inlet at the bottom, diverts either left or right. I am looking for inlet at one side, normally open straight through, diverted out of lower outlet when called ie on a standard diverter inlet B, NO outlet A, not satisfied outlet AB on a normal diverter. Anyone know if it is possible to get such a device?
Sorry have never heard of such a beast as all 3 port valves that I know of can only block off either port A or B they cant physically block port AB, I may be wrong but doubt if you will find one that can do if you want, what is it that you are trying to do that you want a valve like this
Have a look at the Danfoss VZL range:
http://heating.danfoss.com/PCMPDF/VZL2-3-4_VDHDE402.pdf
There are a few different actuators avaialble, e.g. thermic NC, NO..
All, sorry for delay - been out on business. The need was to reduce the amount of pipe re-work to resolve an issue, but in discussing the problem of a reversing solid fuel boiler with a heating engineer, he thinks we can resolve the problem in a different way. Thanks for all assistance.
