30 amp is now randomly tripping? ??
19 Sep 2014
Northamptonshire
Ok so as from this morning my 30 amp fuse on the main box has started tripping
Never done it before . It does the kitchen sockets and upstairs sockets. So I have unplugged everything up and in the kitchen. Reset. Pop it goes......why?.
Is there a way to fault find for a novice at electrics...
Is it the MCB ( works like a fuse when there is too much current flowing )
Or is it the RCD ( trips when electricity is leaking to earth through a fault )
The RCD will have a test button and be marked 30 mA which is 30 milli Amps ( one amp = 1000 milli amps )
It's the rcd then as it has a test/reset button on it. It's strange as never had a problem .no work done anywhere. Just now tripping.cant see any problems with sockets. Upstairs or in kitchen
If you really have unplugged/disconnected everything from the circuit (including boilers etc.), then the problem must be with wiring and/or accessories (like sockets). Water in sockets, junction boxes etc. can make RCDs trip - is there any possibility that this has happened?
You may well have to get an electrician to locate the cause of the problem.
Kind Regards, John
