350mm mitre saw blades ?
21 Apr 2010
Tyrone
Well, needed a small mitre saw quick, bought one off homebase, came with 14tpi blade. Too big. Need a blade of 24-32 tpi. Problem is i cant find one anywhere. Cant return the damned thing, because its been assembled and tried cutting once (which determined that need finer blade...)...
So, mostly all available blades are 550-600mm, and i need 350. any ideas ? Can i argue return of a used item on basis of absent consumables supply (no saw blades)?
Gah...
Ok different track, as most of these blades are induction hardened only the teeth will be hard. So buy a long one and drill it to fit your saw.
