45mm bath fitting
16 Apr 2006
Help! I am middle of plumbing in a new bathroom and am attempting to fit a bath waste filler. But the pre-drilled 45mm hole in the bath will not take the horseshoe shaped spacer (which appears to be 50mm).The spacer has 3 lugs on it , can i cut these off or would it be better to file corresponding holes into the existing hole.
Any words of wisdom out there? as the family is starting to smell :(
Waste Filler :?: ..........Whatever you`ve got it`s not a standard thing for a UK bath....the holes in baths have been the same size for the last 50 years :!: and the waste fittings have been made to fit accordingly :? :?
