700 mm wide bath screen
19 Feb 2015
Would anyone happen to know where I could purchase (or simply the brand name) a 700 mm wide bath screen in a style as shown below? I can only find them in 800 mm width in this style. Thanks.
I had one similar to that. I would not recomend them to anyone. That "missing" bit rougthly a 45 degree triangle will pour out water when in use. Use a longer one or a full length curtain.
Frank
They're 800mm minimum for a reason - 700mm just isn't big enough to be effective
In my case, the bath would be 1400mm long (not the standard 1700mm).
Also, the shower which would be attached to the wall at the end of the bath, this wall is an alcove which brings the shower back from the beginning of the bath by about 200mm. Therefore I would have to ensure that below this, at bath height, that a slightly dipped horizontal tiled section is installed to drip water into the bath.
The comment about the "missing" triangle is interesting, so I could look for a similar one-section screen which doesn't have the rounded corner.
